First Thread - What to do with this 38-116
Would it be reasonable to recap the power stage and not worry about the RF stage? Maybe even cleanly disconnect the RF stage?
Assuming the Iron is good, whats the rough cost to recap one of these? 100, 200, etc. That will depend a lot on how I proceed.....
Is it OK to ask a value on this forum? Or is that against the rules? I understand either way....
RE: First Thread - What to do with this 38-116 - by blown240 - 09-21-2015, 07:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
