First Thread - What to do with this 38-116
Quote:As a side note, when the PO had it powered up, I didn't notice the rectifier tube glowing.
That is probably a good thing! Without the rectifier, there would be no B+ so hopefully no damage was done.
M R Radios   C M Tubes
RE: First Thread - What to do with this 38-116 - by Steve Davis - 09-21-2015, 07:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
