First Thread - What to do with this 38-116
First off. Thanks for the replies, and the respect given to a newb. I appreciate it.
As far as my experience. While its very limited, I did build this:
[Image: http://i268.photobucket.com/albums/jj26/...G_0066.jpg]
[Image: http://i268.photobucket.com/albums/jj26/...010743.jpg]
While its very ugly inside, and I made the mistake of only using 1 color wire, it does work. Though there is an INSANE amount if gain. Too much really.
So I can solder and follow a schematic.
On the back of my radio there are 3 screw terminals. RED/BLACK/GROUND> I wonder if these are a factory input?
RE: First Thread - What to do with this 38-116 - by blown240 - 09-21-2015, 08:27 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
