Philco Radio age?
Hi, and welcome!
If you go to Chuck's website you can look up the Philco models which have a tube layout identical to yours.
Look especially at Models 77 and 96.
http://www.philcorepairbench.com/tube/tubeman.htm
Philco Radio age? - by Guest - 03-05-2009, 06:51 PM
Re: Philco Radio age? - by Ron Ramirez - 03-05-2009, 06:57 PM
Re: Philco Radio age? - by Guest - 03-05-2009, 07:44 PM
There are currently 9621 online users. [Complete List]
» 1 Member(s) | 9620 Guest(s)
