An Interesting Philco Model
That thing has a funny odor to it. Notice that there is no brace across the rear of the cabinet at the very bottom. Cabinets just aren't built that way. Further, the speaker is right smack at the bottom of the cabinet. That's another suspicious looking thing about it. Somehow or another, something just has to have been removed from the lower part of the cabinet, and it's hard to figure out what it is. I'm sure that the cabinet isn't all there.
Of course, I haven't seen every Philco set that's ever been made, but of what I've seen, and even have, Philco just idn't make cabinets like that.
An Interesting Philco Model - by Arran - 03-05-2009, 10:58 PM
Re: An Interesting Philco Model - by exray - 03-05-2009, 11:41 PM
Re: An Interesting Philco Model - by 49Stude63 - 03-05-2009, 11:50 PM
Re: An Interesting Philco Model - by Arran - 03-05-2009, 11:54 PM
Re: An Interesting Philco Model - by Arran - 03-06-2009, 12:02 AM
Re: An Interesting Philco Model - by Doug Houston - 03-06-2009, 12:58 AM
Re: An Interesting Philco Model - by Arran - 03-06-2009, 02:24 AM
Re: An Interesting Philco Model - by 49Stude63 - 03-06-2009, 05:33 PM
Re: An Interesting Philco Model - by Arran - 03-06-2009, 07:12 PM
Re: An Interesting Philco Model - by Ron Ramirez - 03-06-2009, 09:51 PM
There are currently 4044 online users. [Complete List]
» 1 Member(s) | 4043 Guest(s)
