philco 39-71
has any one found a way to clean the tweed covering
[Image: http://i1303.photobucket.com/albums/ag14...fsd7hs.jpg]
sam
philco 39-71 - by sam - 09-25-2015, 04:10 AM
RE: philco 39-71 - by OldRestorer - 09-25-2015, 07:58 AM
RE: philco 39-71 - by Kestas - 09-25-2015, 03:20 PM
RE: philco 39-71 - by Arran - 09-26-2015, 05:11 AM
RE: philco 39-71 - by sam - 09-26-2015, 11:41 AM
RE: philco 39-71 - by sam - 09-30-2015, 07:13 PM
RE: philco 39-71 - by mikethedruid - 10-01-2015, 04:40 PM
There are currently 10573 online users. [Complete List]
» 3 Member(s) | 10570 Guest(s)
