Philco 80 open coils
Also forgot to bring this up. on the osc coil that is open the cap and resistor on the cathode go to ground and are in series after the coil. in my set it looks like these two parts and parallel with the open osc coil. Was this a circuit change for later sets??
I could not find ANY info on this....
Philco 80 open coils - by bastardbus - 09-25-2015, 01:07 AM
RE: Philco 80 open coils - by Radioroslyn - 09-25-2015, 07:54 AM
RE: Philco 80 open coils - by klondike98 - 09-25-2015, 11:52 AM
RE: Philco 80 open coils - by bastardbus - 09-25-2015, 01:11 PM
RE: Philco 80 open coils - by bastardbus - 09-25-2015, 01:14 PM
RE: Philco 80 open coils - by Radioroslyn - 09-25-2015, 05:48 PM
RE: Philco 80 open coils - by bastardbus - 09-25-2015, 10:23 PM
RE: Philco 80 open coils - by bastardbus - 09-26-2015, 01:21 AM
RE: Philco 80 open coils - by Radioroslyn - 09-27-2015, 11:07 AM
RE: Philco 80 open coils - by bastardbus - 09-27-2015, 11:24 AM
RE: Philco 80 open coils - by sam - 09-27-2015, 01:13 PM
RE: Philco 80 open coils - by bastardbus - 09-27-2015, 01:22 PM
RE: Philco 80 open coils - by Radioroslyn - 09-27-2015, 01:27 PM
RE: Philco 80 open coils - by sam - 09-27-2015, 01:30 PM
RE: Philco 80 open coils - by bastardbus - 09-27-2015, 04:00 PM
RE: Philco 80 open coils - by bastardbus - 09-27-2015, 06:24 PM
RE: Philco 80 open coils - by Radioroslyn - 09-28-2015, 07:38 AM
RE: Philco 80 open coils - by bastardbus - 09-28-2015, 04:50 PM
RE: Philco 80 open coils - by Radioroslyn - 10-01-2015, 04:55 PM
RE: Philco 80 open coils - by Radioroslyn - 10-02-2015, 05:50 PM
There are currently 5755 online users. [Complete List]
» 1 Member(s) | 5754 Guest(s)
