First Thread - What to do with this 38-116
From reading your first post....
Option 3 gets my vote.
RE: First Thread - What to do with this 38-116 - by morzh - 09-25-2015, 07:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
