My Latest Restoration - 46-1201
Thank you, Microtouch. Been looking for an alternative as I have 2 other Philcos and a Crosley that need a cartridge to replace the Astatic L70. I saw one on Needle Daddy with a .7 mil needle for 16.95. Is this the one you used?
My Latest Restoration - 46-1201 - by Guest - 03-05-2009, 09:47 PM
Re: My Latest Restoration - 46-1201 - by Guest - 03-05-2009, 11:17 PM
Re: My Latest Restoration - 46-1201 - by Guest - 03-06-2009, 08:27 AM
Re: My Latest Restoration - 46-1201 - by Guest - 03-06-2009, 05:56 PM
Re: My Latest Restoration - 46-1201 - by Guest - 03-09-2009, 05:44 AM
There are currently 10318 online users. [Complete List]
» 1 Member(s) | 10317 Guest(s)
