What is the correct IF for Philco 80
(09-26-2015, 10:01 AM)Radioroslyn Wrote:  Would go with 460kc. Think 450kc is a misprint. Among others 460 and 470kc are common IF fq for '30s Philcos.
I tried both and seems like she was originally closer to 450.  I aligned it to both and seems she likes 450 better.  Anyway to find out for sure?
Also, what are you guys using for alignment tools?  Looks like a 1/4 nut drive.  I have been trying to fudge it with a steel nut driver, removing and checking my meter every turn but would be MUCH easier with a proper tool.  Where could I get one?
T
RE: What is the correct IF for Philco 80 - by bastardbus - 09-26-2015, 03:52 PM
