37-61 photofinish... ideas ?
I wonder if the somewhat reddish appearance may be because the original finishes have darkened with age. I know it happens with other finishes as the varnish yellows, so perhaps the decals are closer to what the radios looked like new than we realize. At any rate, I have ordered a set from Tony at Re-Faux Pro, and will let you see how it works out in a thread recording my work using the Re-Faux process. Tony has been very helpful and is a great guy to do business with.
37-61 photofinish... ideas ? - by mikethedruid - 09-25-2015, 04:28 PM
RE: 37-61 photofinish... ideas ? - by ccomer1955 - 09-25-2015, 04:45 PM
RE: 37-61 photofinish... ideas ? - by ccomer1955 - 09-26-2015, 11:43 AM
RE: 37-61 photofinish... ideas ? - by Ron Ramirez - 09-26-2015, 08:23 PM
RE: 37-61 photofinish... ideas ? - by leftwing25 - 09-27-2015, 05:45 PM
RE: 37-61 photofinish... ideas ? - by mikethedruid - 09-27-2015, 08:44 PM
RE: 37-61 photofinish... ideas ? - by Hank G - 01-30-2016, 03:39 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 01-30-2016, 10:22 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 01-31-2016, 07:26 PM
RE: 37-61 photofinish... ideas ? - by Hank G - 02-03-2016, 04:12 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 02-03-2016, 05:50 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 02-03-2016, 06:42 PM
There are currently 8707 online users. [Complete List]
» 2 Member(s) | 8705 Guest(s)
