First Thread - What to do with this 38-116
Thanks for the comments guys. Hopefully this radio will go to someone who can restore it or appreciate it for what it is.
RE: First Thread - What to do with this 38-116 - by blown240 - 09-28-2015, 12:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
