Philco 37-630
Sure, here you go:
TUNING (double concentric knobs just under the dial)
The other three are, left to right: OFF-ON-TONE, BAND SWITCH, VOLUME.
Philco 37-630 - by phil vanderoef - 03-07-2009, 09:11 PM
Re: Philco 37-630 - by Ron Ramirez - 03-08-2009, 01:55 AM
Re: Philco 37-630 - by phil vanderoef - 03-08-2009, 01:21 PM
