Reproduction Speaker Grill Cloth Buzzing...
Have you talked to Kenny about it yet?  Maybe your piece came from a new batch and he didn't notice how dense it was.
RE: Reproduction Speaker Grill Cloth Buzzing... - by Eliot Ness - 10-01-2015, 10:54 AM
There are currently 11258 online users. [Complete List]
» 2 Member(s) | 11256 Guest(s)
