Philco 60 Antenna Coil
Sorry bout the o-scope slip.
Pretty sure those voltages are good. Heading back into the shop to re-check.
Thanks.
Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 01:04 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 01:19 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 01:47 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 03:18 PM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-02-2015, 02:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 03:24 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-02-2015, 04:38 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 05:11 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:41 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:39 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:45 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 06:03 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 06:07 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 06:21 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 06:30 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-02-2015, 06:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 07:02 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 07:34 PM
RE: Philco 60 Antenna Coil - by Steve Davis - 10-02-2015, 10:40 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 11:39 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 11:20 AM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 12:57 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 01:40 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 02:43 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 04:35 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 05:51 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 06:21 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 07:38 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 08:30 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 09:22 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 09:31 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-04-2015, 09:01 AM
RE: Philco 60 Antenna Coil - by klondike98 - 10-04-2015, 11:42 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-04-2015, 11:54 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 11:41 AM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-06-2015, 02:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 03:00 PM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-06-2015, 09:23 PM
RE: Philco 60 Antenna Coil - by Steve Davis - 10-06-2015, 05:38 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 06:00 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-07-2015, 08:03 AM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-07-2015, 05:08 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-10-2015, 10:35 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-18-2015, 03:58 PM
RE: Philco 60 Antenna Coil - by markmokris - 10-19-2015, 10:02 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-20-2015, 08:30 AM
There are currently 3489 online users. [Complete List]
» 3 Member(s) | 3486 Guest(s)
