Adding fuse to 38-4.
Would like to add an in-line fuse to my 38-4. The switched leg of the power cord travels thru a .015 bakelite cap on its way to the on off switch. Would it be ok to attach the fuse between the bakelite cap and the switch or does it need to be inline before the cap. Thanks, Gary
Adding fuse to 38-4. - by garyh1 - 03-09-2009, 02:06 PM
Re: Adding fuse to 38-4. - by mandh - 03-09-2009, 03:04 PM
Re: Adding fuse to 38-4. - by MinnesotaHam - 03-09-2009, 07:18 PM
Re: Adding fuse to 38-4. - by Arran - 03-10-2009, 05:38 PM
Re: Adding fuse to 38-4. - by g8wayg8r - 05-19-2009, 11:09 PM
Re: Adding fuse to 38-4. - by mandh - 05-21-2009, 07:47 PM
Re: Adding fuse to 38-4. - by exray - 05-21-2009, 08:23 PM
Re: Adding fuse to 38-4. - by codefox1 - 05-22-2009, 03:47 PM
There are currently 10190 online users. [Complete List]
» 3 Member(s) | 10187 Guest(s)
