Adding fuse to 38-4.
When I add a fuse to my restored radios, I always put it before any line capacitors or the on/off switch. If anything fails in the radio the fuse will blow.
Harv
Adding fuse to 38-4. - by garyh1 - 03-09-2009, 02:06 PM
Re: Adding fuse to 38-4. - by mandh - 03-09-2009, 03:04 PM
Re: Adding fuse to 38-4. - by MinnesotaHam - 03-09-2009, 07:18 PM
Re: Adding fuse to 38-4. - by Arran - 03-10-2009, 05:38 PM
Re: Adding fuse to 38-4. - by g8wayg8r - 05-19-2009, 11:09 PM
Re: Adding fuse to 38-4. - by mandh - 05-21-2009, 07:47 PM
Re: Adding fuse to 38-4. - by exray - 05-21-2009, 08:23 PM
Re: Adding fuse to 38-4. - by codefox1 - 05-22-2009, 03:47 PM
