1947 Crosley Radio/Phono
You probably have an old crystal cartridge which has gone bad (they all do eventually).
Syl has posted detailed instructions for rebuilding these here on the Phorum:
http://philcoradio.com/phorum/forumdisplay.php?fid=21
1947 Crosley Radio/Phono - by Bob - 03-08-2009, 09:39 PM
Re: 1947 Crosley Radio/Phono - by Ron Ramirez - 03-09-2009, 06:08 PM
Re: 1947 Crosley Radio/Phono - by Bob - 03-09-2009, 08:14 PM
Re: 1947 Crosley Radio/Phono - by Texasrocker - 03-15-2009, 02:09 AM
Re: 1947 Crosley Radio/Phono - by Bob - 03-15-2009, 07:18 PM
Eico 232 VTVM Schematic
There are currently 9410 online users. [Complete List]
» 1 Member(s) | 9409 Guest(s)
