Which transitone model is this?
This why bakelite is not a bad thing................
Which transitone model is this? - by ccomer1955 - 09-28-2015, 01:12 PM
RE: Which transitone model is this? - by Arran - 10-01-2015, 05:31 AM
RE: Which transitone model is this? - by codefox1 - 10-02-2015, 09:33 AM
RE: Which transitone model is this? - by JimZ - 10-03-2015, 02:43 PM
RE: Which transitone model is this? - by Paul Philco322 - 10-03-2015, 08:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
