Reproduction Speaker Grill Cloth Buzzing...
The sad thing is I think I am going to yank this repop stuff and try and re attach the original cloth back in place.  It was quite faded and smoke stained and now torn in a couple spots from removing it but the radio sounded GREAT with it in place.  It might not look as pretty as the new cloth but I find myself no longer listening to the thing now.  I was listening to it every night before.
T
RE: Reproduction Speaker Grill Cloth Buzzing... - by bastardbus - 10-06-2015, 12:11 AM
