My latest find - Philco 37-630 EZ code 122
(10-06-2015, 12:03 PM)JimZ Wrote:  These EZ models are interesting for me.  Interesting the subtle differences in cabinet detail.  Im remembering the 610T
a forum member bought not too long ago that also was slightly different.
It looks like the subtle inlays weren't used on the export version(OP's example) but that's some nice veneer none the less
http://www.philcoradio.com/gallery/1937a.htm#ai
Hi JimZ
yes, the cabinet don't have the details. I like more the USA model.
Regards,
Regards from Portugal,
Carlos
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
