Adding fuse to 38-4.
If the line condenser is ahead of the power switch I would seriously consider rewiring it so it is on the other side of the switch, I'm surprised that Philco would design a set this way, that's more of a Zenith trick which I hate. You could add a fuse on the primary side, on either leg or both, or add one on the filament/cathode leg of the rectifier where it heads to the filter condensers.
Best Regards
Adding fuse to 38-4. - by garyh1 - 03-09-2009, 02:06 PM
Re: Adding fuse to 38-4. - by mandh - 03-09-2009, 03:04 PM
Re: Adding fuse to 38-4. - by MinnesotaHam - 03-09-2009, 07:18 PM
Re: Adding fuse to 38-4. - by Arran - 03-10-2009, 05:38 PM
Re: Adding fuse to 38-4. - by g8wayg8r - 05-19-2009, 11:09 PM
Re: Adding fuse to 38-4. - by mandh - 05-21-2009, 07:47 PM
Re: Adding fuse to 38-4. - by exray - 05-21-2009, 08:23 PM
Re: Adding fuse to 38-4. - by codefox1 - 05-22-2009, 03:47 PM
There are currently 6738 online users. [Complete List]
» 1 Member(s) | 6737 Guest(s)
