Hello I have got a Philco 48-482 that plays with very low volume, is that a tube problem or something else? Mike Icon_biggrin
48-482 - by Guest - 03-10-2009, 06:10 PM
Re: 48-482 - by philco phan - 03-12-2009, 01:40 PM
