Grill cloth for mod. 90 help
I bought some of the same for my model 70 and, holding it up to the original, it looks very close.
Grill cloth for mod. 90 help - by KCMike - 10-08-2015, 09:38 AM
RE: Grill cloth for mod. 90 help - by NostalgiaRadioTime - 10-08-2015, 06:04 PM
RE: Grill cloth for mod. 90 help - by KCMike - 10-08-2015, 08:33 PM
