Any fix for a loctal socket?
I spray the round needle file I use with contact cleaner that leaves a no-ox (De-Ox-Id) residue when I clean the Loktal socket contacts.
YMMV
The tube pins I treat like Exray does.
Chuck
Any fix for a loctal socket? - by mandh - 03-12-2009, 08:08 AM
Re: Any fix for a loctal socket? - by exray - 03-12-2009, 08:27 AM
Re: Any fix for a loctal socket? - by mandh - 03-12-2009, 08:57 AM
Re: Any fix for a loctal socket? - by Chuck Schwark - 03-12-2009, 09:32 AM
Re: Any fix for a loctal socket? - by mandh - 03-12-2009, 04:28 PM
There are currently 9778 online users. [Complete List]
» 2 Member(s) | 9776 Guest(s)
