  • 1 Vote(s) - 3 Average
Phono cartridge retro fit?
It was a fun project! The twins (they are five) enjoyed growing the crystals so that alone was worth it! I'm setting the M-22 aside for a bit and will be working on the D-10 in my 46-1203. Rather than try and rebuild its crystal cartridge I'm retrofitting a Pfansteihl P51-3. I've heard others have had good results with that cartridge. When I get back to the M-22 I'll do as you've done. I want to use a bridged stereo cartridge so I'm not limited to playing only mono records.
Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 03:10 PM
RE: Phono cartridge retro fit? - by Squire - 08-18-2015, 05:51 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-18-2015, 09:11 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 01:44 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-21-2015, 09:18 PM
RE: Phono cartridge retro fit? - by Squire - 08-21-2015, 11:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-22-2015, 07:30 AM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 03:41 PM
RE: Phono cartridge retro fit? - by ODPILOT - 08-24-2015, 06:28 PM
RE: Phono cartridge retro fit? - by Squire - 08-24-2015, 07:16 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-06-2015, 08:13 AM
RE: Phono cartridge retro fit? - by Squire - 09-07-2015, 02:16 AM
RE: Phono cartridge retro fit? - by ODPILOT - 09-10-2015, 08:51 PM
RE: Phono cartridge retro fit? - by Squire - 09-11-2015, 08:08 PM
RE: Phono cartridge retro fit? - by ODPILOT - 09-19-2015, 12:00 PM
RE: Phono cartridge retro fit? - by Squire - 09-19-2015, 07:55 PM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 02:20 AM
RE: Phono cartridge retro fit? - by sam - 10-02-2015, 03:38 AM
RE: Phono cartridge retro fit? - by Squire - 10-02-2015, 03:25 PM
RE: Phono cartridge retro fit? - by ODPILOT - 10-10-2015, 02:54 PM
RE: Phono cartridge retro fit? - by Squire - 10-11-2015, 11:47 AM
There are currently 5909 online users. [Complete List]
» 2 Member(s) | 5907 Guest(s)
