  • 1 Vote(s) - 3 Average
my 37-61 the work...
I have been in touch with Tony at vintageradiolables.com about this, and he has been very responsive. He had to make the decals from photographs of the original radios for this model, since he did not have a cabinet to measure. He and I are working to get them right. Does anybody here know if the blueprints of the original front panels or the original faux finish decals exist ? If so, I would like to get them to Tony so he can better make these decals for us. This goes for any models, not just mine. I think such blueprints would be of GREAT help to him.
my 37-61 the work... - by mikethedruid - 09-27-2015, 04:00 PM
RE: my 37-61 the work... - by mikethedruid - 10-09-2015, 11:30 AM
RE: my 37-61 the work... - by OldRestorer - 10-09-2015, 11:53 AM
RE: my 37-61 the work... - by mikethedruid - 10-09-2015, 12:18 PM
RE: my 37-61 the work... - by mikethedruid - 10-11-2015, 04:58 PM
RE: my 37-61 the work... - by Ron Ramirez - 10-12-2015, 03:58 PM
RE: my 37-61 the work... - by mikethedruid - 10-13-2015, 04:50 AM
RE: my 37-61 the work... - by mikethedruid - 10-13-2015, 04:12 PM
RE: my 37-61 the work... - by mikethedruid - 12-10-2015, 06:46 PM
RE: my 37-61 the work... - by sam - 12-10-2015, 08:08 PM
There are currently 10433 online users. [Complete List]
» 1 Member(s) | 10432 Guest(s)
