Newbie looking for part's
Welcome to the Phorum!!  Icon_wave
Have you looked at the resources page on the PhilcoRadio.com site?
http://www.nostalgiaair.org/Resources/907/M0013907.htm has the schematic showing a 34-2064 pilot bulb which corresponds to a #44 bulb as seen at the Philco Repair Bench http://www.philcorepairbench.com/lamps.htm
Checkout Radiodaze.com for decals, bezel, etc.
Newbie looking for part's - by jesster925 - 10-11-2015, 07:45 PM
RE: Newbie looking for part's - by klondike98 - 10-11-2015, 07:54 PM
RE: Newbie looking for part's - by jesster925 - 10-13-2015, 10:01 AM
