RCA C15-3 floor model
Here's my latest project. Found locally in the newspaper and surprised it was would show up here in SC. It's a 15 tube set from 1935 with two sets of double doors. Radio had been completely recapped around 1960 based of the vintage of the caps used. The voltages were good and found a dead 6L7 mixer. Replaced the tube expecting it play well but no go. Cranked up the signal generator and soon discovered all the calibration screws were tighten down! Following re-alignment the radio is very sensitive and selective. Link below for photos. Richard
http://s170.photobucket.com/albums/u250/...3%20radio/
RCA C15-3 floor model - by rghines1 - 04-12-2009, 06:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 09:38 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 10:47 AM
RE: RCA C15-3 floor model - by mikethedruid - 03-14-2021, 10:56 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 11:03 AM
RE: RCA C15-3 floor model - by morzh - 03-14-2021, 12:36 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:55 PM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 02:34 PM
RE: RCA C15-3 floor model - by Brad Winder - 03-17-2021, 12:22 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-17-2021, 08:58 AM
RE: RCA C15-3 floor model - by Arran - 03-17-2021, 07:42 PM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 01:34 AM
Re: RCA C15-3 floor model - by Texasrocker - 04-13-2009, 03:53 AM
Re: RCA C15-3 floor model - by rghines1 - 04-13-2009, 10:02 AM
Re: RCA C15-3 floor model - by exray - 04-13-2009, 11:56 AM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 03:13 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:02 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:36 PM
There are currently 6199 online users. [Complete List]
» 2 Member(s) | 6197 Guest(s)
