Isolation Transformer
Hello Folks,
Someone has given me a variable transformer with isolation. I tested it to make sure it was....
So now it's safer to work on the radio as it is completely isolated from mains. Question is this: With the radio plugged into the isolation transformer, does the test equipment also need to be plugged into the transformer, or should it be plugged in to a standard mains outlet?
Thanks.
Isolation Transformer - by Caperodder - 10-14-2015, 02:19 PM
RE: Isolation Transformer - by morzh - 10-14-2015, 04:28 PM
RE: Isolation Transformer - by Caperodder - 10-14-2015, 04:38 PM
RE: Isolation Transformer - by morzh - 10-15-2015, 02:57 PM
RE: Isolation Transformer - by codefox1 - 10-20-2015, 09:01 AM
Eico 232 VTVM Schematic
