Adding AVC to Early Model 70 - Need Opinion
I tried the same thing on a 1936 Crosley 516 before. As Ron stated, and I agree, there really wasnt any noticable difference in performance after the hassel of adding AVC. However, I guess some sets could be improved, and if nothing else, its a good experiment, and the end results will bear their fruits of labor. Good luck with yor Philco retro-fit!
Re: Adding AVC to Early Model 70 - Need Opinion - by Texasrocker - 03-14-2009, 12:01 AM
