Philco 51-532 paint removal?
I went back and looked at it again, and if it was originally brown and painted later, whoever did that pulled up the labels intact and re-glued them on the ivory paint including the pilot light cover. So I'm betting it is original.
I do kind of like the look of it, though. It reminds me of the front end of a 50s car or truck with its big grill and squared up front.
Charlie in San Antonio
Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 12:04 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:58 PM
RE: Philco 51-532 paint removal? - by Ron Ramirez - 10-16-2015, 10:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 01:12 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 03:58 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 04:10 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 07:09 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 11:26 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-18-2015, 11:48 AM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-19-2015, 12:18 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-19-2015, 02:36 PM
