Philco 51-532 paint removal?
Wow. I read your mind and already got some. It works pretty well. I'm reapplying in some crevices, but the cabinet bare Bakelite has a nice gloss to it underneath. I think I might leave it if the Bakelite brown was an option. I have a small, but tightly joined crack in the top, but I read a technique with superglue and packing tape that I might try. If it looks good, maybe I'm almost ready for reassembly.
Any ideas about what to do with the dial scale?
Charlie in San Antonio
Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 12:04 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:58 PM
RE: Philco 51-532 paint removal? - by Ron Ramirez - 10-16-2015, 10:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 01:12 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 03:58 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 04:10 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 07:09 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 11:26 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-18-2015, 11:48 AM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-19-2015, 12:18 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-19-2015, 02:36 PM
There are currently 10327 online users. [Complete List]
» 1 Member(s) | 10326 Guest(s)
