Adding AVC to Early Model 70 - Need Opinion
etech Wrote:My idea was to continue to use the power detector as is. I would add a IN34A as a second 'avc only' detector. I'm thinking it would probably work OK.
However, your circuit would probably sound better. From what I have read, the power detector circuits are prone to more distortion.
Very, very true - the "power" detectors do introduce a fair amount of distortion. Making that tube into an audio amplifier is a better way to go.
The late 70 sets with AVC work very well. Must be something I did wrong - I don't think Ed Locker had the same problems that I did with mine...I believe his works better? Maybe he will chime in soon with some comments Icon_confused:
Re: Adding AVC to Early Model 70 - Need Opinion - by Ron Ramirez - 03-15-2009, 01:29 AM
There are currently 9388 online users. [Complete List]
» 3 Member(s) | 9385 Guest(s)
