1936 116-122 Cabinet Restoration
Anybody know what kind of veneer this is. I need a small piece for a repair.
Thanks.
[Image: http://i1060.photobucket.com/albums/t458...x20fc8.jpg]
Crist
RE: 1936 116-122 Cabinet Restoration - by Crist Rigotti - 10-18-2015, 07:47 PM
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-19-2015, 04:25 AM
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-20-2015, 11:45 PM
There are currently 10182 online users. [Complete List]
» 1 Member(s) | 10181 Guest(s)
