Philco 51-532 paint removal?
Charlie,
I would wait at least a day. After wet sanding I would rub it out with either Novus #2 or automotive rubbing compound.
Eric
The Villages, FL
Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 12:04 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-16-2015, 09:58 PM
RE: Philco 51-532 paint removal? - by Ron Ramirez - 10-16-2015, 10:39 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 01:12 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 03:58 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 04:10 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-17-2015, 07:09 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-17-2015, 11:26 PM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-18-2015, 11:48 AM
RE: Philco 51-532 paint removal? - by ccomer1955 - 10-19-2015, 12:18 PM
RE: Philco 51-532 paint removal? - by Eric Adams - 10-19-2015, 02:36 PM
There are currently 8682 online users. [Complete List]
» 2 Member(s) | 8680 Guest(s)
