  • 1 Vote(s) - 5 Average
model 20 hum (detector circuit?)
I would try poking around the grids with a .1uf cap to ground to localize the source of the hum. The cap will ground out any signal without messing up the bias. Make sure voltage rating is high enough. An oscilloscope would help here too. And don't forget to check the tube sockets for bad connections.
model 20 hum (detector circuit?) - by Tubesforme - 10-19-2015, 01:11 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-19-2015, 06:23 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-20-2015, 10:01 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 10:57 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 11:39 AM
RE: model 20 hum (detector circuit?) - by morzh - 10-25-2015, 11:08 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:18 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:34 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 11:24 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-27-2015, 08:43 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 11:52 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 03:36 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-30-2015, 06:13 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-31-2015, 10:40 AM
RE: Low continual hum in model 21 - by Tubesforme - 10-23-2015, 11:19 PM
There are currently 6776 online users. [Complete List]
» 2 Member(s) | 6774 Guest(s)
