1936 116-122 Cabinet Restoration
 No, it was definitely not oak that they used originally. Here is a link to a photo gallery of various veneer species, Constantine's gallery is just not what it used to be unless I'm looking in the wrong part of their website, this is from another website:
http://www.crownveneer.com/gallery-all-cuts
And here is another, they have it arranged alphabetically, click on one and they have a gallery for each species:
http://www.veneersupplies.com/categories...__A__-__G/
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-19-2015, 04:25 AM
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-20-2015, 11:45 PM
