1936 116-122 Cabinet Restoration
Arran,
I know it wasn't Oak. But I thought it might be close. Looking at the links to the samples, I think Anigre wood might work well too. Might just take another drive up to Rocklers to have another look.
Crist
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-19-2015, 04:25 AM
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-20-2015, 11:45 PM
RE: 1936 116-122 Cabinet Restoration - by Crist Rigotti - 10-21-2015, 01:58 AM
