39-17 Grille cloth supplier?
Who has the most correct grille cloth for my 39-17 cabinet that Fred just finished for me?  What item number or name is it?  Thanks, Steve
[Image: http://www.surfacezero.com/g503/data/500...170350.JPG]
39-17 Grille cloth supplier? - by SteveG - 10-21-2015, 04:56 PM
RE: 39-17 Grill cloth supplier? - by klondike98 - 10-21-2015, 05:43 PM
RE: 39-17 Grille cloth supplier? - by Ron Ramirez - 10-21-2015, 06:45 PM
RE: 39-17 Grille cloth supplier? - by SteveG - 10-21-2015, 07:11 PM
RE: 39-17 Grille cloth supplier? - by SteveG - 10-22-2015, 11:01 AM
RE: 39-17 Grille cloth supplier? - by sam - 10-22-2015, 02:31 PM
RE: 39-17 Grille cloth supplier? - by Ron Ramirez - 10-22-2015, 03:08 PM
RE: 39-17 Grille cloth supplier? - by klondike98 - 11-12-2015, 12:39 PM
There are currently 8742 online users. [Complete List]
» 3 Member(s) | 8739 Guest(s)
