ozarka v16
Murph, neat looking radio. I hope to got it! If so, looking forward to pictures. As Bob indicated, the speaker should be no problem if the field coil is good. Nice if the OT is good but not a show stopper. Cones are not brain surgery to replace, even I have done some!
Good luck, Jerry
ozarka v16 - by murf - 10-19-2015, 02:37 PM
RE: ozarka v16 - by radiohenry - 10-19-2015, 04:45 PM
RE: ozarka v16 - by Arran - 10-20-2015, 03:56 AM
RE: ozarka v16 - by JimZ - 10-20-2015, 08:14 AM
RE: ozarka v16 - by Arran - 10-20-2015, 10:22 PM
RE: ozarka v16 - by Jayce - 10-20-2015, 03:38 PM
RE: ozarka v16 - by Arran - 10-20-2015, 10:17 PM
RE: ozarka v16 - by TA Forbes - 10-22-2015, 09:24 AM
RE: ozarka v16 - by joybird - 10-22-2015, 09:56 AM
RE: ozarka v16 - by murf - 11-06-2015, 09:30 PM
RE: ozarka v16 - by jerryhawthorne - 10-22-2015, 03:26 PM
RE: ozarka v16 - by murf - 10-22-2015, 03:32 PM
RE: ozarka v16 - by joybird - 10-22-2015, 03:32 PM
RE: ozarka v16 - by murf - 11-06-2015, 10:00 PM
RE: ozarka v16 - by mikethedruid - 10-22-2015, 07:17 PM
RE: ozarka v16 - by Eliot Ness - 11-08-2015, 11:53 AM
RE: ozarka v16 - by murf - 11-11-2015, 07:47 PM
RE: ozarka v16 - by murf - 12-26-2015, 06:18 PM
RE: ozarka v16 - by joybird - 12-26-2015, 07:11 PM
RE: ozarka v16 - by rlongoria1 - 06-19-2019, 04:04 PM
There are currently 10467 online users. [Complete List]
» 2 Member(s) | 10465 Guest(s)
