Philco 8B56 clock
Two suggestions come to mind. Take the movement to a qualified clock repair shop and ask them for an estimate on repairing it; or, look on eBay under "synchronous clock movement" You will find many examples. Look on your movement for any identifying numbers and its physical appearance, and see if any match.
Philco 8B56 clock - by klondike98 - 10-22-2015, 05:19 PM
RE: Philco 8B56 clock - by mikethedruid - 10-22-2015, 07:03 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:31 PM
RE: Philco 8B56 clock - by OldRestorer - 10-22-2015, 07:35 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:39 PM
RE: Philco 8B56 clock - by klondike98 - 11-01-2015, 08:34 PM
RE: Philco 8B56 clock - by OldRestorer - 11-01-2015, 08:53 PM
RE: Philco 8B56 clock - by klondike98 - 11-02-2015, 12:05 AM
There are currently 10908 online users. [Complete List]
» 2 Member(s) | 10906 Guest(s)
