Threads: 310
City: Kings Park NY
using bleack is working.
I carefully apply it to the repair and let it sit for 30 minutes. Then re-apply. this pic is after 3 coats.
I thought it would smell but hardly any odor.
Image(s)
AC: 4 DC: 1
RE: Rons Tropic 42-788 - by OldRestorer - 10-23-2015, 10:44 AM
Users browsing this thread: 24 Guest(s)
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM
Transistors are easy.
Or touch your fin...morzh — 04:25 PM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM
There are currently 10077 online users. [Complete List ]» 1 Member(s) | 10076 Guest(s)
