Question On ID Of Radio
Texas Rocker, I checked the schematics at Nostalagia Air, and the radio schematic not listed. This is 6 tube, some of the tubes; Nat-Nal Nx 245, 247, 56, RCA 58, after some cleaning, on the back of set has tag "phono" . The dial attached to chassis has numbers 0-100 as stated earlier, and believe it is 1920's wooden cabinet, made by Red Lion.I am going to try get metal from other two tubes to see the numbers. I've googled no luck. Thank you, bigdog
Question On ID Of Radio - by bigdog - 03-14-2009, 07:11 AM
Re: Question On ID Of Radio - by Texasrocker - 03-15-2009, 01:46 AM
Re: Question On ID Of Radio - by bigdog - 03-15-2009, 08:50 AM
Re: Question On ID Of Radio - by bigdog - 03-18-2009, 06:53 AM
