Adding AVC to Early Model 70 - Need Opinion
An early Model 70 without AVC will be super-sensitive...because, with no AVC to reduce the gain of the receiver on strong broadcast signals, the receiver is operating at "full throttle" all of the time. On a later Model 70 with AVC, the gain will vary depending on the strength of the received signal due to the AVC action.
I used to have Ed Locker's modified 70 schematic around here somewhere, but with my newer computer currently being dead, I'm not sure if it is stored on it or not.
Re: Adding AVC to Early Model 70 - Need Opinion - by Ron Ramirez - 03-18-2009, 05:29 PM
There are currently 9015 online users. [Complete List]
» 3 Member(s) | 9012 Guest(s)
