  • 1 Vote(s) - 5 Average
model 20 hum (detector circuit?)
I don't think it is the transformer vibrating because the hum stops when he pulls the 27 tube.
M R Radios   C M Tubes
model 20 hum (detector circuit?) - by Tubesforme - 10-19-2015, 01:11 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-19-2015, 06:23 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-20-2015, 10:01 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 10:57 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 11:39 AM
RE: model 20 hum (detector circuit?) - by morzh - 10-25-2015, 11:08 PM
RE: model 20 hum (detector circuit?) - by Steve Davis - 10-26-2015, 08:38 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:18 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:34 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 11:24 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-27-2015, 08:43 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 11:52 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 03:36 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-30-2015, 06:13 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-31-2015, 10:40 AM
RE: Low continual hum in model 21 - by Tubesforme - 10-23-2015, 11:19 PM
There are currently 6668 online users. [Complete List]
» 2 Member(s) | 6666 Guest(s)
