37-61 bakelite block question
Yes, Chris, Looking closely at it, it seems there are tiny wires coming through the end two eyelets, but not the middle one. I am wondering if the middle one is just being used as a tie point. I am still not sure which of the condensers in the circuit is hiding inside. Tracing the wires, it seems as if it may be part number 40, the .03 mfd condenser, but I am not sure, and, of course, when I take it apart, I probably won't be able to read anything on whatever is inside, if it is at all like the other block. If anyone has encountered this also, and knows, please let me know.
37-61 bakelite block question - by mikethedruid - 10-26-2015, 04:07 PM
RE: 37-61 bakelite block question - by OZ4 - 10-26-2015, 05:17 PM
RE: 37-61 bakelite block question - by mikethedruid - 10-26-2015, 06:19 PM
RE: 37-61 bakelite block question - by OZ4 - 10-26-2015, 09:04 PM
There are currently 5886 online users. [Complete List]
» 2 Member(s) | 5884 Guest(s)
