Just picked up a 41-295
No taping diagram. It is a "fixed" primary side with 6 pins for the speaker side, i.e. It just sets the ratio primary to secondary. The speaker is hanging on the bench at the moment, ill take some pictures so you can see the recone job...
John
Las Vegas, NV USA
Just picked up a 41-295 - by LASJayhawk - 04-27-2015, 07:18 PM
RE: Just picked up a 41-295 - by OldRestorer - 04-27-2015, 07:46 PM
RE: Just picked up a 41-295 - by John R - 04-27-2015, 07:51 PM
RE: Just picked up a 41-295 - by Phlogiston - 04-27-2015, 10:32 PM
RE: Just picked up a 41-295 - by mikethedruid - 04-29-2015, 06:41 PM
RE: Just picked up a 41-295 - by jerryhawthorne - 04-30-2015, 04:06 PM
RE: Just picked up a 41-295 - by LASJayhawk - 10-24-2015, 09:22 PM
RE: Just picked up a 41-295 - by LASJayhawk - 10-25-2015, 07:05 PM
RE: Just picked up a 41-295 - by John R - 10-26-2015, 04:40 PM
RE: Just picked up a 41-295 - by klondike98 - 10-25-2015, 09:54 PM
RE: Just picked up a 41-295 - by LASJayhawk - 10-26-2015, 08:36 PM
RE: Just picked up a 41-295 - by LASJayhawk - 10-26-2015, 08:41 PM
RE: Just picked up a 41-295 - by LASJayhawk - 11-01-2015, 10:28 PM
