Philco 60 4th style?
Bob,
It's the one on the right side marked July '34 or the one on the left, second row marked June'35. That's the style cloth.
Philco 60 4th style? - by SteveG - 10-27-2015, 11:01 PM
RE: Philco 60 4th style? - by klondike98 - 10-27-2015, 11:08 PM
RE: Philco 60 4th style? - by Ron Ramirez - 10-27-2015, 11:15 PM
RE: Philco 60 4th style? - by SteveG - 10-27-2015, 11:17 PM
RE: Philco 60 4th style? - by Ron Ramirez - 10-27-2015, 11:20 PM
RE: Philco 60 4th style? - by klondike98 - 10-27-2015, 11:21 PM
RE: Philco 60 4th style? - by SteveG - 10-28-2015, 01:03 AM
RE: Philco 60 4th style? - by OldRestorer - 10-28-2015, 06:43 AM
RE: Philco 60 4th style? - by Ron Ramirez - 10-28-2015, 09:05 AM
RE: Philco 60 4th style? - by SteveG - 10-28-2015, 11:04 AM
RE: Philco 60 4th style? - by klondike98 - 10-29-2015, 04:14 PM
