Philco 60 4th style?
Thanks Ron. Now to get that radio home. Anyone have thoughts about shrinking the stretched spot before I have to consider replacing the grille cloth??
Philco 60 4th style? - by SteveG - 10-27-2015, 11:01 PM
RE: Philco 60 4th style? - by klondike98 - 10-27-2015, 11:08 PM
RE: Philco 60 4th style? - by Ron Ramirez - 10-27-2015, 11:15 PM
RE: Philco 60 4th style? - by SteveG - 10-27-2015, 11:17 PM
RE: Philco 60 4th style? - by Ron Ramirez - 10-27-2015, 11:20 PM
RE: Philco 60 4th style? - by klondike98 - 10-27-2015, 11:21 PM
RE: Philco 60 4th style? - by SteveG - 10-28-2015, 01:03 AM
RE: Philco 60 4th style? - by OldRestorer - 10-28-2015, 06:43 AM
RE: Philco 60 4th style? - by Ron Ramirez - 10-28-2015, 09:05 AM
RE: Philco 60 4th style? - by SteveG - 10-28-2015, 11:04 AM
RE: Philco 60 4th style? - by klondike98 - 10-29-2015, 04:14 PM
There are currently 10175 online users. [Complete List]
» 1 Member(s) | 10174 Guest(s)
